My Philco 91X, no longer ignored.
I was bored this afternoon and finally decided to dig my 91X back out and at least play it a little. This radio was already recapped when I got it, but the bottom (woofer) speaker was a bit crippled from an old accident and major repairs to the cone. Basically, the old glue had caused the cone to warp over the years and it would buzz. The tweeter has some repairs too, but is in much better shape. Well, after playing it good and loud for about a half hour, the speakers seemed to come around and I ultimately enjoyed listening to the radio for two hours solid. The tone is rather good for this era of radio, especially with the tone set all the way counter-clockwise into the first position. So, it now is out and set up to be played more often instead of burried behind other radios. Icon_smile
The 91 is a good playing set! I had one years ago it was a chairside with a big old separate speaker cabinet. In the cabinet was the dual speakers like your set. At the time I wished that it had some SW coverage.
Jayce. Thats a neat looking set design. Glad to here the speaker started sounding better after playing awhile. How many tubes does that have?
The 91X has nine tubes and uses push-pull 42's on the output. The dual speakers do seem to make a difference on this set. Icon_thumbup
The dual speaker system was primative but agree the sound is very good!!
My model 14 LZX features the dual speakers, in fact it is playing now next to me as I type this. The 14 and 91 (early) are pretty much the same set.
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 5318 online users. [Complete List]
» 1 Member(s) | 5317 Guest(s)
