Philco 90 console
Picked up a 90 console today off of CL
A little moisture damage on the feet but appears unmolested.
Nice findIcon_thumbup!! Looks like a first series chassis with the local/distance switch on the back. Good luck with it!
Kevin
Looks like another good find. You guys are causing me to kick my searching up a notch.
That is a great find, Tim! Yep, it's an early model with the PP-45s and the local/distance switch!!
Icon_thumbupIcon_clapIcon_wave
Way to go! Nice find!
Gene
Thanks, I almost gave-up on getting a reply from the CL seller.
I guess his Spam blocker was working overtime!
Tim, a very nice find and one of my favorites. I had a latter chassis and recently gifted the radio off to a friend for a house warming. Just need to make room for another console. Great radio.
Jerry
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 2116 online users. [Complete List]
» 3 Member(s) | 2113 Guest(s)
