Philco 38-690/Pictures
I Posted some pictures on my first post.
I would love some feed back on what you guys think it is worth?
Ray
Doesn't posts #7 and #13 give you an idea ?
My friend says he will fix radio. I am going to buy it.
Thanks everyone.
Ray
You will enjoy it. Mine sounds terrific. The refinish on that looks great.
Beautiful radio. If you like it, go for it. Life's too short.
Congratulations! Icon_clap Icon_clap Icon_thumbup
Beautiful radio......It is on my wish list...
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
