ron you son-of-a-gun!!
you just stole my 60 chassis on ebay!!! Icon_lol
i needed the dial scale to finish my radiobar,if you don't need it,let me know,phil
I saw TWO 60 chassis closing today on ebay.
hey exray,haven't seen you around lately,how's things in the middle of the ocean? i saw the other chassis but the dialscale is a mess,thanks for pointing it out,phil
Phil - PM sent.
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
