Was there ever a Philco 38-25?
I was at an antique store yesterday, and saw a Philco console with a model #38-25 (I did not write down the model number or take a picture, so I could be wrong but I did memorize the number before I left the store). Anyways, after I got home, I paid a visit to the usual sites (This site, Nostalgia air, radioatticarchives, radiomuseum.org) to find information about this model and was surprised to find absolutely no info on this model...It has a five-tube chassis (I was unable to determine the types of tubes) and has three bands with a rectangular dial and push-button tuning. Anyone know if this critter ever existed?
Don
Hi Don
To briefly answer your question...no.
Now to explain: Philco did not introduce pushbuttons or the rectangular slide rule dial until they brought out their 1939 line of radios in June 1938. The Model 39-25 fits your description, however.
Thanks, Ron! As I said earlier in my post, I was relying on my not-so-reliable memory for the model number. I did look up the picture of the 39-25 on your website, and it does look like that, so it may have been a 39-25 after all Icon_redface
Don
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
