philco 41-250
howdy! just finishing this up,schematic has ant. term number 1 connected to output tranny.why?external input?
thanks,phil
http://www.nostalgiaair.org/PagesByModel...013407.pdf
Used as alignment test point. I have never used it. I use the AVC line.
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
hi terry,thanks,i was thinking along those lines also,would be the same as across the speaker,phil
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4351 online users. [Complete List]
» 1 Member(s) | 4350 Guest(s)
