To restore or not to restore?
Threads: 310
City: Kings Park NY
AC: 4 DC: 1
Threads: 551
City: Jackson, NJ
Looks original to me.
Actually short of some scratches it does not look bad at all after Gojo.
(This post was last modified: 05-23-2014, 01:24 PM by
morzh .)
Threads: 55
City: Evanston, IL
Not bad at all.
I'd just lightly touch up the scratches to match the newly revealed "cleaned" tones.
Also stealthy re-glue any wood joints to make it sturdier to handle the chassis weight once re-united.
The rear arch supports are notorious for being loose or missing.
I think repros are available for the support.
I'd think you should be able to correct the control knob set too.
Nice find. See Ron's Galleries for cabinet pics and knob styles/sizes.
http://www.philcoradio.com/gallery/1931b.htm
Chuck
Threads: 42
City: Ironton Ohio
FWIW, I have 2 70's and the veneer on the back arch/case has a beautiful bookmatched figure that on your radio looks to have been covered with brushed on varnish stain. If that is the case, then I would defiantly refinish it as to see the figure in the veneer.
Threads: 551
City: Jackson, NJ
The two bottom knobs I think are OK, it is the middle which probably not even Philco, and the top that should be large rosette?
And in some 70 all three bottom knobs can be small ones.
Threads: 310
City: Kings Park NY
That's what i thought too Todd, it looks like a bad staining job. The front arch looks original al but the face is also splotchy.
AC: 4 DC: 1
Threads: 15
City: Weymouth Ma
What to do depends on what your plans for the radio are. I tend to agree with Chuck. I am sure that you can make it look better. But are you going to keep it or sell it? My self I hate to see old radios that look over done. It's really a matter of how you feel.
Henry
Threads: 310
City: Kings Park NY
It is a keeper. 99% of them are. Just trying to decide if the finish is original or not.
AC: 4 DC: 1
Threads: 51
Try some alcohol on it, they may have slobbed shellac all over the original lacquer. You really have nothing to loose by trying it, I had a radio with a blotchy yellowish look, even after the Gojo treatment, tried some rubbing alcohol on it and it came off revealing the original finish underneath.
Threads: 310
City: Kings Park NY
Sounds good! will try that
Thanks
AC: 4 DC: 1
Threads: 33
City: Horsham, PA
I would redo the whole thing, especially if I had your ability.
Threads: 18
You can fix cabinet, how about the insides?
Threads: 310
City: Kings Park NY
She is dirty but looks untouched except for one filter cap. Haven't removed the chassis. I have to finish my other radios before I open another one.
Image(s)
AC: 4 DC: 1
Threads: 70
City: Linn Creek, MO
Kirk, it looks like your 70 is the less common late version with AVC.
M R Radios C M Tubes
Threads: 310
City: Kings Park NY
OOH less common! $$$$$$$$$$$$
Good for my family when they sell it after my death.
Thanks Steve
Kirk
AC: 4 DC: 1
Delco car radio Peko vibrator converstion issues
Rich,
There is an Australian website (Cool386.com) that has much useful info regarding repair and restoration of vibr...Joe Rossi — 07:29 PM
Jackson 715 not working
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red.
Red is Bad.
Green is Clean.morzh — 01:30 PM
(Insert Homer Simpson "DOPF" Here.)
When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil.
It wo...morzh — 08:44 AM
There are currently 3346 online users. [Complete List ]» 2 Member(s) | 3344 Guest(s)
