Philco Flying Wedge 48-230
Threads: 2
City: Costa Mesa CA
I bought this thinking about restoring it and then selling it on eBay, but now I like it too much and will likely keep it. I noticed some electrolytic caps were installed that differ from the schematic. Should I go back and replace what the schematic shows, or use similar values to the replacements?
Also wondering if I did want to sell it down the road..is it more valuable as restored and working or left in it's original condition?
Threads: 269
City: Bandon
State, Province, Country: OR
Welcome to the Phorum!!
The exact values of the electrolytics are not critical but if I were restoring it I would use the values that were in the schematic and stuff them into the original electrolytic container if its still there. You should also change out the paper capacitors and check the resistors and replace if they have drifted more than 20% above their spec.
As to value I'll let others with more ebay seller experience comment
Threads: 2
City: Costa Mesa CA
OK, good. That's pretty much what I thought as well. Thanks!
Threads: 2
City: Costa Mesa CA
Well, after recapping and checking/changing resistors, tubes and wiring...no stations. A little background noise, but no static or anything. Checked tube voltages, which were a little high and low here and there. I get hum from touching center lug of volume knob. I checked the wiring on the 3 coils, and they looked OK. What else can I do? I don't have a signal generator.
Threads: 70
City: Linn Creek, MO
The next thing to check would be the oscillator. Place a working radio tuned to clear spot on the dial around 1450. Now, tune the 48-230 to around 1000 and rock the dial. If your oscillator is working, you should be able to hear it in the working radio.
M R Radios C M Tubes
Threads: 551
City: Jackson, NJ
Have you checked you tubes?
Threads: 2
City: Costa Mesa CA
Yes, I checked the tubes, swapped tubes, measured voltage. I'm going to clean the sprockets and check that all pins are making contact next.
Steve-when you say rock the dial do you mean tune it up and down slightly?
Threads: 551
City: Jackson, NJ
I am sure there are more than three coils in there. Check them all.
Threads: 70
Quote:Steve-when you say rock the dial do you mean tune it up and down slightly?
Yes, Tune the 48-230 a little each direction. You should hear a change in the other radio.
Threads: 2
City: Costa Mesa CA
IF in, IF out and Osc coils. 3 there and nothing else. I'll run tests when I get home today.
Threads: 2
City: Costa Mesa CA
Steve-thanks for that oscillator test. It worked! I swapped the 2 IF coils from a working Philco and it still has no sound. Power section, audio, IF, Osc all work but why no stations?
Threads: 70
If you have a schematic that you can post, it might help us find the problem.
Threads: 2
City: Costa Mesa CA
OK, I attached a 2 sheet and then a blow up of the schematic. Thanks!
Threads: 70
Do you have a signal generator?
Threads: 2
City: Costa Mesa CA
No signal generator. That would make it too easy, wouldn't it!
Jackson 715 not working
Mrfixr55, its working now. I cleaned the switches and sockets with spray cleaner. Thanks for helping on this one.daveone23 — 06:26 PM |
Now that you posted the schematic, I don't know why that Sprague electrolytic cap is across the meter, as it is not indi...MrFixr55 — 05:51 PM |
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM |
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM |
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red.
Red is Bad.
Green is Clean.morzh — 01:30 PM |
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM |
(Insert Homer Simpson "DOPF" Here.)
When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM |
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil.
It wo...morzh — 08:44 AM |
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM |
As Rod said, it is OK to use a fitting speaker, and then look for an original one.
If you buy a Hammond 125 output tr...morzh — 08:15 AM |
There are currently 3947 online users. [Complete List] » 1 Member(s) | 3946 Guest(s)
