Shadow meter bulb?????
I am still working on my6 Philco 3650 and when I got it there was a bulb for the shadow meter in a small metal case and I don't see any way that it attaches behind the meter.. I would like to see a photo of the bulb in place.. Everything works But I don't know how the bulb stays in place.
Dan
http://www.antiqueradios.com/forums/view...5&t=241024
http://mcclellans.com/Philco16BCathedralRestoration.htm
http://www.tuberadioland.com/philco91d_main.html
http://www.ebay.com/itm/PHILCO-SHADOW-ME...3f39e57c12
(link is eBay but provided for clear picture's sake).
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4297 online users. [Complete List]
» 1 Member(s) | 4296 Guest(s)
