Globe tubes
I bought recently a pair of used globe power tubes. They both checked out fine, tested them on my radios. Bases are tight. What concerns me is that there are some flakes inside the tubes when one turns them upside down. Can I keep them or send back?
That would be the material used to coat the filament so electrons are given off at a lower filament temperature. I have found over the years that tubes that have been abused electrically, ie: over heated due to bad caps, tend to do this. I have also noticed lately that some of my NOS early globes are doing the same thing and they have never seen any service so not sure what to make of it. The biggest problem with this is this material can cause a short in the tube if it gets between a couple elements.
Gregb
That's very common in rectifier tubes and not worth worrying about.  I would be surprised if I didn't find those flakes of cathode coating in my 80's.
Pete AI2V
I also have those flakes in some 45 and 47 globes. What kind of the worst scenario damage may occur while using them?
Prrobably OK, especially if kept operating in standard vertical position, base down. Might not like service in a helicopter or at sea.
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
Hello Chas. Radiomuseum has information on both sets.  Thanks Gary, lots of good info there. Perhaps we'll ha...ChasL0001 — 02:23 AM
There are currently 1975 online users. [Complete List]
» 1 Member(s) | 1974 Guest(s)
