Threads: 48
City: Freehold, NY
Ron,Chuck or anybody,
Can you please ID this phono? I think it is a 41-RP serries but unsure of which one. I have a RP2 so I am pretty sure it is not that one.
http://cgi.ebay.com/6589712873
thanks,
Chris
Hi Chris
It is the first version of Model RP-2, from January 1939.
If you win it, please send me some pictures of it. I don't have a good photo of this model. Thanks...and good luck!
Threads: 55
City: Evanston, IL
My guess, looking at the 1941 and 42 product cut sheets, is a 42-RP2, since the case is smooth, the 41-RP2 has a moulded front on the lower case. Circuit-wise they are almost identical, between the 41 and 42 versions. Case may also have been refinished at one time, since the photo-finish "veneer-inlay" strip is missing on the lower case.
{EDIT, later that same morning.} Ok, maybe not.......
This is a 42-RP2:
[Image: http://www.philcoradio.com/gallery/image...42rp2o.jpg]
(Photo credit: Bob Timms)
Notice that this one has no half-round moldings, and it is wider at the base.
(edit) Now, a mid-season 1939 Model RP-2, which is identical with the item on our favorite online auction site:
[Image: http://www.philcoradio.com/gallery/images/1939/rp2o.jpg]
Threads: 48
City: Freehold, NY
Thanks for the information. Hopefully I will win it.
Thanks again,
Chris
HOOOLLLLYYYY COOOWWWWW!!! That thing went for 81 buckazoids! A bit ridiculous, if you ask me, for one of these units.
No, I take that back. Not just a bit ridiculous - more like WAY over the top. Don't think I've ever seen an RP-x bring that much money, save for the more rare RP-3 that looks like a big Mystery Control on steroids, only without the dial.
Chris, hang in there, there will be another one, and more reasonably priced. (I'm assuming you aren't "monique-renea," right? ...Right? )
Threads: 48
City: Freehold, NY
Ron,
No I am not. I was very disappointed I did not win it. I don't understand why it went that high! I got my RP2 for $25! Will keep my eyes open. Still have not gotten to restoring the RP2 yet. Too many radios not enough time
thanks
Chris
I think $25 is more like it for these models. Chris. One man's opinion. Someone must have wanted it BAD for a Christmas present or something?
Jackson 715 not working
Now that you posted the schematic, I don't know why that Sprague electrolytic cap is across the meter, as it is not indi...MrFixr55 — 05:51 PM |
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM |
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM |
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red.
Red is Bad.
Green is Clean.morzh — 01:30 PM |
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM |
(Insert Homer Simpson "DOPF" Here.)
When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM |
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil.
It wo...morzh — 08:44 AM |
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM |
As Rod said, it is OK to use a fitting speaker, and then look for an original one.
If you buy a Hammond 125 output tr...morzh — 08:15 AM |
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM |
There are currently 3675 online users. [Complete List] » 2 Member(s) | 3673 Guest(s)
