Phonograph with Philco by Radiobar
Since I sorta got this thread off-topic for a bit, I'm going to start a new thread dedicated only to the Phonograph with Philco by Radiobar.
Pat
Here are some pics of the unit sent to me by the PO. He just delivered the unit to me yesterday, so I haven't had a chance to go through it yet. Someone out there MUST have more information on this. All I can find is what Ron has, including the Mulholland Press info.
Cabinet made and marketed by Radiobar, a Philco 38-3 chassis, and a Capehart automatic record changer.
[Image: http://i1367.photobucket.com/albums/r796...6mu61p.jpg]
[Image: http://i1367.photobucket.com/albums/r796...3atcur.jpg]
[Image: http://i1367.photobucket.com/albums/r796...yhieir.jpg]
[Image: http://i1367.photobucket.com/albums/r796...ptvf1d.jpg]
WOW  that looks great Icon_thumbup
looks pretty good condition too.  maybe just touch up ?
you could always send out to east coast if you don`t have room for it Icon_mrgreen
sam
(07-25-2015, 11:30 AM)sam Wrote:  WOW  that looks great Icon_thumbup
sam
Yeah Sam, I think you're right. Maybe just touch up. Except for the lid. The inside of the lid is pristine, including the felt, but the top HAS to be refinished.
And I DON'T have room for it, so it will be on ebay when I'm done. 'Course shipping wouldn't be too cheap. It measures 42x37x19, and has to weigh more than 100 lbs.
Pat
Nice restorations! I merged your two threads as they are primarily both about the same set.
(07-25-2015, 03:12 PM)klondike98 Wrote:  Nice restorations!  I merged your two threads as they are primarily both about the same set.
O.K. Thanks
Pat
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4623 online users. [Complete List]
» 2 Member(s) | 4621 Guest(s)
