Label Image Needed -Solved!
I'm wondering if anyone has a good photo of the bottom label for a 48-460 Code-122 Hippo? The label on mine was roached so I didn't try and save it before I stripped the cabinet. The only flaw in an otherwise great cabinet is on the bottom where a small piece was broken out and glued back in. A replacement label will cover the flaw and the radio will be that much better. I found an image online, but it has a water stain across at least half of it so I'd like to find a better example if possible. Any help would be greatly appreciated!
Thanks!
Dan
Edit - Vintage Radio Labels is working with me to get a set made!
