Threads: 310
City: Kings Park NY
Well,
I got the tubes today and put them in. The radio came on and I was happy but the noise was loud and not controllable by the volume.
Is this a backwards E-Cap? or is it those big ol' resistors. I have to check them still. I am very careful with the E-caps so I dont think I messed that up.
Any ideas?
AC: 4 DC: 1
If one or both resistors were open, the tubes would not light up (they are part of the series filament string).
If you had installed an electrolytic backwards, you would have known it right away by the loud POW! like a firecracker or gunshot from the electrolytic failing from being connected backwards.
So...so far so good, it seems...
Threads: 530
City: Jackson, NJ
Kirk
1. What you need to do has to be done NOT IN YOUR GARAGE, or on the gound floor or near grounded anything. No it is not a true hot chassis but still no galvanic isolation.
2. Hook a good antenna.
3. Try to SLOOOWLY rotate the tuning cap and see if there is any reception at all.
Threads: 310
City: Kings Park NY
No reception, just the loud hum even with volume at zero.
I'll try the long antenna but the hum will still be there.
What could it be?
I'd let you get it working but I don't want that 116 cabinet
Plus you still have the Silvertone 45 to play with.
(when you decide to take on that challenge)
Kirk
AC: 4 DC: 1
(This post was last modified: 09-05-2014, 01:16 PM by
OldRestorer.)
Threads: 530
City: Jackson, NJ
Oh don't worry, if not 116, you re getting that 16 cathedral
You did keep the original coils in that 45? (or what's left after those french chefs dined on it)?
(This post was last modified: 09-05-2014, 01:47 PM by
morzh.)
Threads: 530
City: Jackson, NJ
Hum means the buzz/60Hz type?
Or crackling/noise?
What is your #5 cap value? (the one across the field oil)?
And another, alo #5, at the left of the sch, next to the vertical dashed line?
(This post was last modified: 09-05-2014, 01:56 PM by
morzh.)
