Removing old labels
Got a repro label for my Philco 71 to replace the original that had mostly flaked off.  Need to remove the remains of the old one before putting on the new one, but what's left is not coming off easily.  Any suggestions on the proper way to remove it?  Naphtha, perhaps?
Are you asking about the Philco logo decal on the front of the cabinet or the Philco model # label on the tube shield? I think the model # label would soften up with isopropyl alcohol though I haven't done it.  If its the front decal, then I assume you are not refinishing the cabinet and are just trying to take off the decal.  I've done that once on a 42-322 cabinet using GOJO (without pumice) and 0000 steel wool to gently take off the decals.  I was lucky and they came off without making any visible difference in the finish...that may not be possible in all cases.  Others may have other approaches.
I'm talking about the decal on the back of the chassis that has the model type and a bunch of patent numbers.
Edit: Specifically, I'm talking about the gold toned one in the upper right: http://www.vintageradiolabels.com/philco-model-71.html
(11-22-2014, 05:40 PM)captainslack Wrote:  I'm talking about the decal on the back of the chassis that has the model type and a bunch of patent numbers.
I removed one w/ a blade of a knife as seen in this thread - http://antiqueradios.com/forums/viewtopi...6&t=253316
I later had it laminated and glued back. That part is in the thread there as well.
I then tried same method on a different radio and it didn't go so well. I stopped and then just covered it w/ clear packing tape.
Acetone would probably get the old label off. But that stuff is very strong and should be used outdoors while wearing good rubber gloves and a respirator. Always think of your health first before using harsh chemicals!
