39-6ci
i've seen the pics here but i need a side view,are the sides white also?
mine has been completely stipped and i need to repaint it,i can see the black trim on the front on pics here,thanks,phil
Hi
Can't help you with side views, but I can tell you that the sides and top are also ivory, as is the front (note: ivory, not white).
Trim is black, as you noted.
Hope this helps.
howdy ron,good to here from you. is antique ivory a good match? i have a spray can that i used on a belmont 6d111 that matched perfectly,thanks,phil
Well...if it looked good on the Belmont, then it should look well on the Philco. Icon_smile
