if can on model 42-1003 code 121
confused on schematic, the if can before the 7c6 has 5 wires in it grn,blue,black,red and white. the black wire is center tapped in the secondary side of the transformer but nowhere on the schematic. at present i have connected it to pin 4 on the 7c6 but i do not think this is right. getting 455khz tone all the way to the primary side of the transformer but no further. the 50l6 is not producing anything thru a speaker but i can get something when using signal tracer.any ideas?
(01-19-2015, 12:12 PM)mountain man Wrote:  confused on schematic, the if can before the 7c6 has 5 wires in it grn,blue,black,red and white. the black wire is center tapped in the secondary side of the transformer but nowhere on the schematic. at present i have connected it to pin 4 on the 7c6 but i do not think this is right. getting 455khz tone all the way to the primary side of the transformer but no further. the 50l6 is not producing anything thru a speaker but i can get something when using signal tracer.any ideas?
There are three additional components inside this I.F. as shown on the schemo. 45A,C & D I believe. Anyways they are two 100pfd caps and a 47K resistor as shown below the 7C6 tube on the schematic. The black wire has to connect the two 100 pfd caps to the 7C6 cathode pin 7. Good luck.  Icon_thumbup John
Thanks John, I guess I need  a refresher course in schematic interpretation, never noticed that but at 75, Icon_lol I have a good excuse. going to replace all if can wiring as they are all cracked and some exposed so replacing caps are a must while I'm there.
(01-19-2015, 06:26 PM)mountain man Wrote:  Thanks John, I guess I need  a refresher course in schematic interpretation, never noticed that but at 75, Icon_lol I have a good excuse. going to replace all if can wiring as they are all cracked and some exposed so replacing caps are a must while I'm there.
The first time I took a similar Philco IF apart to replace the rubber wires I thought - where are the 100pf caps?
The resistor was a common carbon comp. but I found the caps are built into the ceramic substrate and are not replaceable themselves. I measured with a LCR meter and indeed there was pf readings where the caps are to be located. I think these caps are supposed to shunt any extraneous RF to ground. The 47K in yours is actually in line with the AVC buss.  Icon_crazy John
John, glad that You told me this as i found no caps in the if can in question, thought I was loosing it for sure but now I know. The 7c6 which follows the last if can is a little difficult to understand but the problem lies in that area, unfortunately someone was there before me so now my problem is even further aggravated. Ah the joys of radio repair especially for the novice. Thanks for your input, would be better if You lived next door Icon_lol
Philco 46-480 Cabinet Restoration
I have since gotten the cabinet stained and toned. I saw a video online of another guy renovating a 46-480, and he used ...jrblasde — 07:37 PM
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
There are currently 1934 online users. [Complete List]
» 1 Member(s) | 1933 Guest(s)
