Philco 511 restoration question
Hello forum-
Still working on the 511 and I have a question about the 3 -0.1uf capacitors which are wrapped with coil (one per RF circuit).  Are these tank circuits?  What modern type are to be used for replacement ? Do I just use regular caps and leave the coils intact?  Any clarification is appreciated.
Mark
I stuffed mine with yellow tube caps and 1/4w 100 ohm resistors, then I wrapped thread around the old cap to mimic the wire resistor. Then I used a black crayon to melt into the ends. Looks completely original.
