Threads: 22
City: Acworth
State, Province, Country: GA
I've rewound this and now I'm having a hard time
trying to solder leads to it. This 40 gauge wire keeps
burning up when I try to solder it. I've using a Weller
8200 and even at 100 watts setting it burns. Do I need
to buy a pencil, if so which do you recommend? Or is there
another process to connect leads?
Thanks....
Danny
Threads: 54
City: Lexington, KY
Yeah, a 100 watt gun is probably most of your problem. If you don't want to spring for a soldering station like the Weller WESD51 or WES51 you can use a 25 watt iron or maybe even a 45 watt if you're careful. I prefer a temperature controlled iron, but an el-cheapo like the following will easily get you by:
https://www.parts-express.com/variable-w...s--370-340
Look at the 2nd review by the guy in Lexington.... he is a friend of mine and he loves that iron.
If you are cheap like me you can remove the tip and make a larger (longer) one with coat hanger. The longer the cold.
A technique I learned and used: take a thick gauge copper wire, like the one used for house wiring or just a tad thinner, and tightly wrap it around your 100W tip, as many turns as fits. Then allow about 1-1/2 to 2" long tip, shape it with a file to a bevel. It is excellent to use for small wires. The ratio of tip length to number of turns dictates the temperature.
Threads: 7
City: Portland OR
I have run my 35 watt pencil iron on a variac to reduce the heat, not great regulation if the house voltage is jumping around, but works good for quick job.
Hank
Threads: 22
City: Acworth
Great help thanks everyone....I do appreciate all the replies,
Morzh...I tried your suggestion and it worked great.
Danny
