Threads: 36
City: Brandon, SD
I haven't had time to do any research but does anyone know if the speaker from a 1936 model 116X console would work in a 38-116? I have a 38-116 that has a totally shot speaker in it. Was just wondering. I will do some research later.
Most speakers will, but 38-116 had some dual-type cone, with thicker middle responsive to high pitches and softer outer part. Otherwise, maybe mechanical etc but should work.
Philco used two different speakers during production of the 38-116. Both (W-4 and W-5) have identical specs. Both have 350 ohm fields.
The speaker used in the 1936 model 116B (U-9) has a 1450 ohm field.
So...the U-9 will not work in the 38-116.
You can find specs for all 1929-1936 Philco speakers here:
http://www.philcoradio.com/phorum/showth...hp?tid=215
Go to the link, and download the file
speakers.zip.
