1941-42 Philco Radio Model #50-T
I have just installed a nice 1941-42 Philco Products Ltd, Toronto, Canada table model #50-T radio in my kitchen.
It sounds pretty good but I'm wondering how do you set the five station push buttons. One button if for off/on and the other five are not doing anything right know. I can tune stations manually but not with the buttons.
Any suggestions of what to do or where to get a users manual. Hope somebody can lend a hand. Warm regards
Gord Morrison up in Canada.
 Hi Gordon, I tried to find info you need but couldn't. You might try
 Just Radios
they sell schematics and are in Canada. I think a lot of the push button adjustments are fairly simular, you migt try searching for the 1940/41 USA. made philcos with push button tunning and read how to adjust.
        Good luck.
Hi Gord Welcome to the Phorum!
Try looking here for one that looks like it:
http://philcoradio.com/gallery/1940b.htm
or
http://philcoradio.com/gallery/1941a.htm
Then look up the US model # here:
http://www.nostalgiaair.org/Resources/303/T0000303.htm
As Mike said most are pretty generic.
Unfortunately, the Philco (Canada) 50 does not have a USA equivalent.
It is very similar to the Canadian 51A, but with a single ended output instead of the push-pull output in the 51A.
I own a 51AT and I wrote about its restoration here just over a year ago:
http://philcoradio.com/phorum/showthread.php?tid=11039
As Mike mentioned, try Just Radios for the schematic.
Philco 39-116 radio and remote
The transformer I located is from a Philco TV chassis, circa 1948. The part number is 32-8391 I do have the replace...Brad Winder — 08:59 PM
Philco 41-221 Restored
Hello Rod, Wow that radio looks great nice job ! Sincerely Richardradiorich — 07:39 PM
Philco 269 - 444 FIVE VALVE VERSION?
From what I can remember the model 444 "People's Radio" used a special tube/valve called a PenDD61, it was the...Arran — 06:54 PM
Nice Radioslford310 — 06:24 PM
Hi Chaz,  You may want to post the tubes used in your radio.   From Radio Museum, it seems that the set uses some ...MrFixr55 — 05:14 PM
Today my grandson and I finished the restoration of this Philco 41-221. It has had all the rubber coated wiring replaced...RodB — 03:19 PM
Hi Brad, I had no idea that the overheating was problematic in this radio.  Do you know the part number of the transfor...RichG — 03:01 PM
From the photo it looks the sockets are screwed and the front one does not even match the hole.morzh — 02:54 PM
Hi Chas a welcome, Perhaps we'll have to reverse engineer this to sort it. So let's start w/what tubes does it use? And...Radioroslyn — 12:28 PM
Hi Rich, From my experience, unfortunately it is not uncommon to find the power transformer in the 39-116 to be overhea...Brad Winder — 09:25 AM
