need help on 49 Zenith mod 5D-810Y
Im "scratchin" my head on this restoration of this simple small 1949 mod bakelight radio ac/dc Zenith AM chassis.!(hee hee!) Ive carefully replaced all the caps. The sets working with a "intermittent" shorting in-out from full vol to low vol prob in the front-end. This chassis is the simple 5-tuber, 50L6,& following minature tubes lineup of the era. The set is working, audio section is very stong until the vol "intermittently" shuts down drastically. I have re-checked all tube pins, socket connections, etc very carefully. Ive subbed in a known-good set of spare(s) tubes from another good 100% working (similar) chassis. The prob sounds like a bad-resistor trying to correct itself, but all orig resistors check within fairly near specs, or, very close.The orig antenna-coil checks good this time!!!(hee hee)
Ive traced the prob back to the 2-gang mechanical tuning condensers "mica" adjustments, and/or, the possibility of a IF coil intermittent short in one or both the 455kc cans simply by "tapping" on them. Since the orig 1 meg audio taper Vol/on-off control was bad, I already replaced that also. My voltage checks under chassis are all good point-to-point. When I tap on the tuning-condenser, I get full volume then it immediately drop off again to very low volume. Im overlooking something simple here, and hope I dont need to pull the IF trans if not necessary? Your thoughts please. The orig loop antenna is good also, and the set performs very well when the front-end is "intermittenly" working properly for those few minutes after complete tubes warmup. This set has the isolated ground B- , and 5 tube filament string. Any Ideas?? Icon_wink
This may be the dreaded silver mica disease inside the IF transformers. The schematic shows they are adjusted with the ferrite slugs which are the most prone to this problem.
If so you are likely hearing some static thunderstorms. Sometimes use a simple RF grounding probe that is easy to build. Take a old test probe and wire a 0.1uf 630V poly cap in series with the probe. Connect one of the probe to -B with the other end used to ground out tube pins such as plate and grid. With patience it is possible to isolate the problem to a particular stage with the divide and conquer approach.
Richard
If tapping the tuning cap does something as you note, try tuning to a station at the very highest point on the dial (minimum capacitance in the tuning cap) and see if it happens there. If the problem goes away, you probably have a shorting plate in the tuning cap.
If you problem happens with a minor rotation of the tuning cap, you may have lousy connections in the tuning cap rotor wipers.
A third thing to consider: a temperature sensitive resistor will always look just fine when measured with an ohmmeter; it's only when it's hot and current flowing that the problem will be seen. Let the radio heat up fully and when the problem begins, start spraying each resistor, starting with the largest wattage, with some freeze-spray. You can also speed up time by heating the underchassis with a heat gun- but not too much.
Pete AI2V
Thanks for your help Pete & Richard! These type sets arent my faves to service!!! Im hoping the silver-micas in the tuning-slug type IFs are OK? I did get the set working again without the "intermittent" prob so far. I noticed while I was carefully probing around the under-chassis point-to-point connections, I got full-vol by pushing fairly hard on one of the orig solder connections at the 2nd IF primary connections. Low & behold, I added abit of new solder to orig Zenith( cold solder joint) and the set came on full vol as it should. Ive bench tested it now for approx 4 hrs without any dropouts in performance. The set now receives stations all across the dial. Since this is a customers radio, I will let it play on the workbench several more hrs to see if the micas are also bad in the IF cans before I rtn it to customer.
Another prob I found on my workbench, is my vintage AC isolation trans is "upping" my actual AC line voltage! I didnt realize that until I checked. My actual incoming AC line voltage is running around 124 volts, & my AC Isolation trans outlet was reading around 134 volts AC! If I had realized that, I would have cranked the Iso Trans AC back down with my variac!Wonder whats up with that happening with my Iso Trans also?
I copied your posts to keep in my files for future reference on these type chassis repairs!! Thanks again!! If the set fails again, I know what to check next via your suggestions! Icon_wink Randal
Philco 46-480 Cabinet Restoration
I have since gotten the cabinet stained and toned. I saw a video online of another guy renovating a 46-480, and he used ...jrblasde — 07:37 PM
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
There are currently 1752 online users. [Complete List]
» 2 Member(s) | 1750 Guest(s)
