Philco 37-10 magnetic tuning problems
Threads: 43
City: Chicago, IL
I recently dug into my first Philco - a 37-10 with automatic / magnetic tuning - and set out to restore it.
[Image: https://farm4.staticflickr.com/3030/2989...64f5_z.jpg]
[Image: https://farm6.staticflickr.com/5679/2375...c9d9_z.jpg]
It worked fairly well well when I got it then sat in a closet for a few years. This was my first good luck under the chassis and I was surprised to see so little work had been done to it. Just a few new electrolytics and paper caps. I later found that the volume and tone controls had been replaced too.
[Image: https://farm6.staticflickr.com/5776/2402...e36f_z.jpg]
[Image: https://farm2.staticflickr.com/1442/2375...9c47_z.jpg]
[Image: https://farm2.staticflickr.com/1503/2405...1b61_z.jpg]
Threads: 43
City: Chicago, IL
Next I recapped it including unmounting the RF unit so I could really get down in there.
[Image: https://farm2.staticflickr.com/1580/2346...8e21_z.jpg]
Replaced all the rubber mounts while I was at it.
[Image: https://farm6.staticflickr.com/5829/2398...05a9_z.jpg]
All the bakelite and electrolytic caps were restuffed.
[Image: https://farm2.staticflickr.com/1673/2359...0d36_z.jpg]
[Image: https://farm2.staticflickr.com/1704/2419...59a8_z.jpg]
I also discovered the 2M volume control had been replaced with a 500K and the tone/power switch replaced with a potentiometer and switch. I got replacements from playthings of the past and restored the original wiring.
[Image: https://farm2.staticflickr.com/1557/2427...55e5_z.jpg]
[Image: https://farm2.staticflickr.com/1619/2430...54c0_z.jpg]
The radio played great on the first power up Plenty of volume and selectivity. However, the "magnetic tuning" feature doesn't seem to be working.
[Image: https://farm2.staticflickr.com/1576/2406...87f8_z.jpg]
Turning it on and off has almost no effect on the tuning. It certainly isn't locking in on a station. I did some voltage checks and found the 6N7 oscillator control tube only has around 180 volts on the plates. The service info states 260. That voltage is derived from the junction of the 10K and 15K in a bleeder network of 10K, 15K and 51K.
(This post was last modified: 01-14-2016, 06:32 PM by Bob Andersen.)
Threads: 43
City: Chicago, IL
Huh, it's working now  I just kept poking around and finally got the discriminator coil to peak
Here's a look inside the IF / descriminator can for the curious. The variable cap at the top is the one I had trouble peaking. Maybe my opening up the can and blowing the dust off fixed it ?
[Image: https://farm2.staticflickr.com/1620/2401...9a6c_z.jpg]
Threads: 273
City: Wilsonville
Threads: 337
City: lawrenceville nj
Great looking bob
Great vid too
Sam
Threads: 43
City: Chicago, IL
Thanks! Next installment uploading right now where I demonstrate the magnetic tuning. It really does work well once properly adjusted.
Threads: 69
City: Kansas city, MO.
Very nice job, and thanks for posting the magnetic tuning video.
Threads: 41
City: Shepherdsville, KY
Hi Bob
Really like your YouTube vedios.  I just finished a magnetic tuning philco, I had to read the alignment instructions several times before I got it right. Especially tuning the AFC. Keep up the good work.
Joe
Threads: 43
City: Chicago, IL
Thanks! Does anyone know where I can get a new dial glass ? I suppose I could pick up a piece of glass any try cutting it myself but the curves look tricky
[Image: https://farm2.staticflickr.com/1503/2377...696a_z.jpg]
Threads: 41
Hi Bob
Joe
Threads: 337
hey bob
I think I have a 38-116 glass around here
that should be the same yes??
sam
Threads: 43
City: Chicago, IL
Hmm. I don't think so. It looks like the side are straight in the 38-116 while angled a bit in the 37-10. http://www.tuberadioland.com/images/phil...16x_13.jpg
Threads: 54
Bob;
Maybe you could trace out the shape onto cardboard and get a glass shop to cut a new piece? That is unless you know someone who does a lot of stained glass work, they would have the tools to cut and grind glass.
Bob
Have you considered plexiglass? I cut a piece of plexiglass for that type of escutcheon once, several years ago...it wasn't easy, but a heck of a lot easier than cutting real glass...and looked fine once installed in the escutcheon.
Or if you decide to go with real glass, Arran's suggestion to go to a place that does stained glass work sounds like an excellent suggestion.
Threads: 43
City: Chicago, IL
Thanks for the tips! I'll see what I can do. Meanwhile, I've been reassembling the automatic tuning mechanism and have a few questions.
1. What type of bulbs should be used ? I found two types installed - #44 and some fat 3W bulbs.
[Image: https://farm2.staticflickr.com/1632/2431...fe1d_z.jpg]
2. There is a chrome reflector ring around behind to station identifier tabs. I'm pretty sure all four bulbs should point towards that reflector but the top two on mine point forward. That only illuminates the inside of the cabinet! Should I bend them so they point into the dial ?
[Image: https://farm2.staticflickr.com/1677/2431...a4e4_z.jpg]
[Image: https://farm2.staticflickr.com/1492/2431...2b67_z.jpg]
3. Finally, I'm confused about the audio muting switch. I understand that it should short out the audio to ground when the tuning handle is pressed in. The inner contact on mine is just sort of floating around inside. I think it should line up with the other contact mounted on the shaft. Not sure if I'm missing something that would secure it in position.
[Image: https://farm2.staticflickr.com/1711/2442...d8c1_z.jpg]
[Image: https://farm2.staticflickr.com/1608/2442...8c2a_z.jpg]
an anyone shed some light on these issue ? Thanks!
(This post was last modified: 01-16-2016, 11:47 PM by Bob Andersen.)
I just remembered, I have some hi temp silicone rubber material which could do the trick. Or a piece of FR4 laminate. Th...EdHolland — 08:39 PM |
The PSU filter cap arrived today (thank you USPS!) so I will work on that later.
Meanwhile, I have the dial, speaker...EdHolland — 06:42 PM |
Thanks Terry. After checking my notes I think I recorded about -10v at the 6A7 G4/control grid. The screen grid (G3 &...Tubester — 05:59 PM |
Magical chords of forgotten melodies, old nostalgic music on an old radio... Saturday night blues on the Mid-Waves on an...RadioSvit — 12:20 PM |
Thank you MrFixr55 the issue with this radio is that the internal coil antenna is missing and there was a wire in its pl...osanders0311 — 11:34 AM |
Regarding the oscillator circuit which is comprised of the 6A7's cathode, control grid, and screen grid. These elements ...Radioroslyn — 10:33 AM |
Hi OSanders,
First off, welcome to the Philco Phorum where Phine Phamily-Phriendly Pholks Phull of Philco Phacts and P...MrFixr55 — 08:41 AM |
Today I've been reading through the site trying to learn more about this radio. I also soldered the lose power cord cabl...osanders0311 — 08:24 PM |
Thanks David! I do have that same later prodution model 610 schematic. I've also studied the Philco service bulletins fo...Tubester — 08:12 PM |
Some info from Beitmans says late production. David David — 06:06 PM |
There are currently 2418 online users. [Complete List] » 3 Member(s) | 2415 Guest(s)
