Speaker Difference H13 vs H16 ?
In need of H13, but see a H16 available
Anyone know specs on these 2 speakers?
Bob T
http://www.philcoradio.com/phorum/showth...hp?tid=215
Specifically, the file Philco Speakers - speakers.zip.
Now:
Both are 10-1/2 inch speakers.
H13 - 1125 ohm field @ 65 mA; output transformer primary 5,900 ohms push-pull to match 1.25 ohm voice coil
H16 - 660 ohm field @ 80 mA; output transformer primary 7,200 ohm single-ended to match 1.25 ohm voice coil
If you were to use an H16, you would need to add resistance in series with the field or else your B+ would run too high. Plus you would have to replace the output transformer with a suitable push-pull unit.
Thanks Ron
Looking for the H13, but may have to bite on the H16
What do you think chances of finding the H13 are ?
Bob T
Bob, it would seem that you shouldn't have too much difficulty finding an H-13 as it was used in many Philco models such as:
16B, 18D, 18H, 18L, 18X, 116B (early), 118D, 118H, 118X, 118MX, 503L, 507L
and in the following - consoles only: 650, 655, 660, 665
However...as popular as model 16 (and 116B) sets are, that may limit your ability to find a good one.
Good luck! Icon_thumbup
A couple questions about this.  I was talking to Bob (joybird) about a speaker I have, that I acquired in what I believe is a 16RX cabinet.
It's a 10-1/2" speaker that looks very much like the speaker in my 16B (version 3), except the cover over the contacts is set up for a flat cable instead of a regular 4-wire harness.  It's stamped H13 on the back of the field coil.  The paper on the field coil is stamped 1126.  The basket of the speaker is stamped UU8U.  Using my VOM, I measure 1102 Ω on the field coil, 289 Ω on the primary of the audio transformer, and less than 0.5 Ω across the voice coil and audio xfmr secondary.
I would think from the UU8U stamp that this is a U-8 speaker, but according to the list a 16RX should have a U-2.  What do I have here?
That is an H-13. The "U" speakers were a completely different design.
M R Radios   C M Tubes
Thanks Steve. So why does this style cabinet have an H13 speaker?
According to Ron's list, it should be a U2, right?
Philco 39-116 radio and remote
The transformer I located is from a Philco TV chassis, circa 1948. The part number is 32-8391 I do have the replace...Brad Winder — 08:59 PM
Philco 41-221 Restored
Hello Rod, Wow that radio looks great nice job ! Sincerely Richardradiorich — 07:39 PM
Philco 269 - 444 FIVE VALVE VERSION?
From what I can remember the model 444 "People's Radio" used a special tube/valve called a PenDD61, it was the...Arran — 06:54 PM
Nice Radioslford310 — 06:24 PM
Hi Chaz,  You may want to post the tubes used in your radio.   From Radio Museum, it seems that the set uses some ...MrFixr55 — 05:14 PM
Today my grandson and I finished the restoration of this Philco 41-221. It has had all the rubber coated wiring replaced...RodB — 03:19 PM
Hi Brad, I had no idea that the overheating was problematic in this radio.  Do you know the part number of the transfor...RichG — 03:01 PM
From the photo it looks the sockets are screwed and the front one does not even match the hole.morzh — 02:54 PM
Hi Chas a welcome, Perhaps we'll have to reverse engineer this to sort it. So let's start w/what tubes does it use? And...Radioroslyn — 12:28 PM
Hi Rich, From my experience, unfortunately it is not uncommon to find the power transformer in the 39-116 to be overhea...Brad Winder — 09:25 AM
