Wattage Rating for Two Philco Resistors
Does anyone know what the wattage rating is for these Philco resistor part numbers:
33-1171 (1 MEG)
33-1169 (500K)
Geoff
Juxging by the values you do not need more than 1/4W anywhere in a radio.
Those usually were 1/2W resistors they used for such values.
Thanks.  It is for my Philco 640 (schematic attached).  I have a scan of a Philco Radio Parts Catalog from 1936 and was able to find the wattage for all other resistors with the exception of those 2.
I dunno what the mfr specs are but you don't need anymore than I wrote.
The sole reason I use higher wattage is the resistors are longer and so can span more gap when soldered between remote points.
Thanks!!!
Philco 46-480 Cabinet Restoration
I have since gotten the cabinet stained and toned. I saw a video online of another guy renovating a 46-480, and he used ...jrblasde — 07:37 PM
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
There are currently 2043 online users. [Complete List]
» 3 Member(s) | 2040 Guest(s)
