  • 1 Vote(s) - 1 Average
First Radio Resto - Philco 60B
Solamar Wrote:I did notice that IF tube (should be a 78 per schematics) has been swapped for a 77. Was that a running change or did someone put the wrong tube in?
Not a runnning change - notice it was not mentioned in the comprehensive Evolution of the Philco Model 60 thread. Put the proper tube (a 78 ) in there. Your radio will thank you.
Did notice that your filter caps are a bit odd. On the bottom normally they would have a solder lug in the center not a wire. Would bet that they have been restuffed with different caps than what is printed on the label. And yes the - side of the caps are not at chassis ground they are at B-. If you where to connect them to the chassis it would short out the negative voltage that the power supply develops from the power transformer hv winding center tap to the bias resistor.
The 77 and 78 share the same pinout but the characteristics are different. Will work but will better with the 78.
Will do.
(08-10-2016, 07:44 PM)Radioroslyn Wrote:  Did notice that your filter caps are a bit odd. On the bottom normally they would have a solder lug in the center not a wire. Would bet that they have been restuffed with different caps than what is printed on the label.
Hah, you are absolutely correct, good eye! I just checked and the bottom of the caps is actually foam rubber with a slit for the wires to come out.
I found a source for some (fairly) original 8mf cans to restuff.  All put back together and powered up and it's performing good, but not great.
Tunes in most AM channels that I can pickup with my modern AM radio.  There was a fairly bad 60Hz buzz in the background, adding a ground lead to the chassis helped remove about 75% of the buzz but it's still annoying.
My plan is to start working through the bakelite caps now.  I plan to do them one at a time and test function (worried about making a mistake that will be hard to trace...).
Is there a logical sequence to replace the bakelite caps?
I have (edited with values found)
#7  3615-AJ  .05  .05  (Will use two .047uf 600V orange drops)
#27 8035-B  .00011 .00011 (Will use two 100pf 500V Silver Mica)
#30 3903-AP .01 (Will use .010uf 600V orange drop)
#33 8035-D .00011 .015 (will use 100pf 500V silver mica and .015uf 600V orange drop)
#49 3793-W .015 (will use .015uf 600V orange drop)
From Philcorepairbench I have found the parts list for all except 8035-B and 3793-W.  Is there a better list to discover whats inside these?
Also, are there other capacitors besides the bakelites that I should replace?
Thanks for the great info!
Matt
There is more data here
http://philcoradio.com/phorum/showthread.php?tid=14964
(08-16-2016, 05:23 PM)klondike98 Wrote:  There is more data here
Thank you!  So the two I couldn't find are discontinued with replacement P/N's, got it.
Looking at DigiKey, 300, 500 or 1000V Mica caps?  General purpose or RF High Frequency?
So what number are they on the schematic or actual capacitance ? Not the philco p/n.
(08-16-2016, 06:08 PM)Radioroslyn Wrote:  So what number are they on the schematic or actual capacitance ? Not the philco p/n.
I updated post #20 with the schematic number and capacitance.
Well this is kinda odd.
I had a 77 tube in place where a 78 tube should have been (I.F.), radio ran fine. I installed a used 78 tube and it motor boats badly. Tube tested a bit low so I put in another 78 that tested good. Motor boats just as bad.
Any ideas what is going wrong?
Matt
I just finished up replacing all of the capacitors in the bake lite housings.  3903-AP did not make sense, it's replacement part is 3903-OSU which is a .01 uf between pins 1&3.  My 3903-AP clearly had the capacitor between pins 1&2 so that is how I wired the replacement.
I must have done something wrong.  The radio powers up, all tubes glow and there is a soft hum coming from the speaker.  The volume and the tuner dial effect nothing, hum remains constant.
While working on condensor 7 (3615-AJ) I must have broken the solder joint to the resistor leading to condensor 30, easy fix and every other connection appears good.
Any suggestions on areas to start troubleshooting?  I'm good with a multimeter, decent with schematics and fair/poor with radio theory...
Thanks for any help,
Matt
Check pm box.
Terry (radioroslyn) is not only exceptional at troubleshooting these radios, but a very patient man for putting up with me!
He rather quickly led me to a problem in the #33 bake lite condensor that was sending 160v to the control grid.  Turns out that I shorted the legs of the two capacitors inside the bake lite  Icon_sick
The radio is back up and running now (Thank you Terry!).  But I still have the motor boating problem.  If I tune in a strong channel the motor boating goes away, but it overwhelms most week channels.  If I put back in the incorrect IF tube (77) motor boating goes away.
Any advice on tracking down this problem?
Matt
Hey Matt,
Glad to help out and get your set back in the pink. Enjoyed chatting with you.
You can try adj #26 just a little and see if it calms it down. Add more capacitance to #20 and or add a cap at the bottom of the second IF transformer at the B+ connection, .05 or .1mfd @ 630v is fine. Keep leads as short as necessary to make connections. Also have a look at that 2meg resistor to be sure it's close to 2 megs ( it's part of the avc circuit).
(08-25-2016, 01:36 PM)Radioroslyn Wrote:  Hey Matt,
Slight adjustment of Trimmer # 26 and motorboat is gone!
I just finished swapping out the Filter bank capacitors, re-assembled the radio and she's playing beautifully Icon_e_biggrin
Greatly appreciate all the help!
Matt
