12-23-2016, 05:45 PM
New here. I recently learned Philco in 1942 modified the model 801 car radio into a home model inserted in a end table with 115 vAC renamed the 801-A. I am curious how this AC conversion was manifested.
Model 801 conversion to AC question
12-23-2016, 06:06 PM
Welcome to the Phorum!
I moved your post down into the regular thread section. Here's the schematic for the AC version from Nostalgiaair. http://www.nostalgiaair.org/pagesbymodel...013909.pdf
12-23-2016, 11:52 PM
Hi and welcome,
Well the in a nut shell version is that they remover the vibrator and power transformer. PT got replaced w/one w/a 120 primary (old one had a 6v @ 100cy). Looks like most everything is the same between the two chassis. Believe the car chassis is a C-1908 and the chairside is a A-801 When my pals were reading comic books I was down in the basement in my dad's workshop. Perusing his Sam's Photofoacts Vol 1-50 admiring the old set and trying to figure out what all those squiggly meant. Circa 1966 Now I think I've got! Terry
12-24-2016, 12:43 AM
I believe that they converted these pretty much as Terry suggested, even leaving the original rectifier and filter cap can. I've never owned one, though I would like to at some point, but from the photos I have seen they didn't have enough room on the chassis of the MoPar 801 to bolt an AC power transformer so they screwed a vertically mounted transformer inside the cabinet and extended the leads to connect to the car radio chassis. I believe that in the consoles that used a Ford car radio chassis they did have enough space to mount an AC power transformer on the chassis, or at least on the outside of it.
Regards Arran
12-25-2016, 12:18 AM
(12-23-2016, 05:45 PM)RAH1915 Wrote: New here. I recently learned Philco in 1942 modified the model 801 car radio into a home model inserted in a end table with 115 vAC renamed the 801-A. I am curious how this AC conversion was manifested.Thank you Guys, I was not certain where the question would fit as it was originally a car radio but ended up as a piece of furniture or a home radio. I am familiar with Nostalgia web site but apparently missed that one. Thanks again and have a wonderful Holiday and New Year.
12-26-2016, 12:42 PM
Welcome. Here is a thread from ARF that might help you.
http://antiqueradios.com/forums/viewtopi...6&t=178029
« Next Oldest | Next Newest »
Users browsing this thread: 1 Guest(s) |
