Philco 20 Grille Cloth
Is there a good reproduction grille cloth available for the Philco 20?
M R Radios   C M Tubes
I think the only one that's close is the one Daze sells. Same goes for 16, 70, 90.
Sam Mashburn used to sell a Model 20 replacement cloth, but he has run out and won't be restocking (from what he told me a couple years ago).
Radio Daze doen't carry a model 20 pattern although they do carry a decent replacement for 70, 90, 71, 91, 16 cathedral, etc. (GRC02).
I was hoping to find some cloth closer to original. I stocked up on 70/90 cloth from Grille Cloth Headquarters before his stock ran out. I guess I will have to use some of that.
Philco 39-116 radio and remote
The transformer I located is from a Philco TV chassis, circa 1948. The part number is 32-8391 I do have the replace...Brad Winder — 08:59 PM
Philco 41-221 Restored
Hello Rod, Wow that radio looks great nice job ! Sincerely Richardradiorich — 07:39 PM
Philco 269 - 444 FIVE VALVE VERSION?
From what I can remember the model 444 "People's Radio" used a special tube/valve called a PenDD61, it was the...Arran — 06:54 PM
Nice Radioslford310 — 06:24 PM
Hi Chaz,  You may want to post the tubes used in your radio.   From Radio Museum, it seems that the set uses some ...MrFixr55 — 05:14 PM
Today my grandson and I finished the restoration of this Philco 41-221. It has had all the rubber coated wiring replaced...RodB — 03:19 PM
Hi Brad, I had no idea that the overheating was problematic in this radio.  Do you know the part number of the transfor...RichG — 03:01 PM
From the photo it looks the sockets are screwed and the front one does not even match the hole.morzh — 02:54 PM
Hi Chas a welcome, Perhaps we'll have to reverse engineer this to sort it. So let's start w/what tubes does it use? And...Radioroslyn — 12:28 PM
Hi Rich, From my experience, unfortunately it is not uncommon to find the power transformer in the 39-116 to be overhea...Brad Winder — 09:25 AM
