I picked up this little Weller iron a couple of yrs ago and I really like it as it has three led lamps on it. The light makes it very handy to use. But as time marches on the tip was getting shorter and shorter. Couldn't find a model # for the iron and didn't want to pay 4 or 5 bucks for a tip that doesn't fit.
So did a little measuring and found that the tip threaded to fit a 10-24 hole. Had the proper die but had to catch a ride to the hardware to get some solid copper wire.The fellow manning the wire section at the HD is a ham that use to be a member of the ham club I was going to back it the lat 80's. We had a few yucks abt the club and such. Found some copper that looked good for the size and off we went. Got home threaded it, used a dremel the shape and it's back in service. Now I can get started on the 116X.
(This post was last modified: 07-06-2017, 05:11 PM by Radioroslyn.)
The key to using the retractable tip iron is to take it out regularly and lightly clean of the oxidation, else it will get stuck. Especially the one with thread on it.
Didn't have any trouble getting out it unscrewed easily. But flux in the solder was eating up the copper(after 3 or4yrs). I had read that cheap folks would not reshape the tip by filing or grinding but would beat it w/a hammer thus saving the copper. But you can only beat it so much.
I tried a 10-24 steel and brass machine screws but too much heat lost. Don't conduct heat as well as copper.
(This post was last modified: 07-06-2017, 03:56 PM by Radioroslyn.)
Nice pics Terry. I also have a similar Weller with the three Led's. I lost the little set screw but shorten one I bought at Home Depot. Nice job with the Tap &Die. I see you take care of your tools. I have a radial arm saw that dates back to the early 80's and still cuts very good. My first power tool was a B&D corded 3/8' drill which I still have from 1975.
I like old tools as long as they work well. I trash pick a '57 Craftsman table saw from a neighbors house many years ago. It broken and thought I might have to fab some parts ( two banana shaped pieces that allow the blade to pivot). Much to my surprise these pot metal parts were still available some 45yrs later. So for abt $40 worth of parts I was up and running. Here's a pic of one like it that I found on the net. Mine is in a shed and can't get to it. [Image: http://philcoradio.com/phorum/images/smi...on_sad.gif]
Used it a lot to make shelves for all of these darn radios!
I googled the Weller iron with the lights and that iron is still stocked in a variety of wattages .Tips too.
It looks interesting I may order one. Check Test Equipment Depot. They carry the entire Weller line.
Henry
I think that next spring, I'm going to start watching local auctions for a nice used Craftsman table saw. I think I would like to try my hand at making a few tuner/receiver cabinets, among other things.
Terry, my dad had a table saw just like yours, except his was on an old gray stand with wheels on the bottom. Top was the same, though. He tossed it when they moved away after he retired, that always kind of bummed me out. It had been my grandfathers at one time and it worked fine.
Greg
