Model 71 code 225 shadow meter
Hi everyone, I have a 71 cathedral with a code 225 chassis. I figured out  (after a while) that code 225 should mean two speakers, this is a cathedral though and the K 7 speaker had separate pins soldered to the three  wires and plugged in the 4 pin socket on the chassis. Was a 2 speaker chassis (221, 223 or 225) chassis ever used in a cathedral cabinet? If so then was a K 7 speaker with a plug used for the attachment? I am guessing all 2 speaker chassis used the 4 pin socket instead of being "hardwired". My main question relates to the shadow meter though, the coil is open. To bypass this , should I solder a resistor across the terminals on the strip on top of  the #8 choke? I replaced the electrolytic caps and am working on the bakelite blocks, the audio section is working after figuring out  the loose speaker pin arrangement. The cabinet is really nice so I want to finish this project. The 71-225 chassis does not match the schematic for a 71-221 and it has the separate tube shields . Any comments and help with bypassing the shadow meter are welcome.
I have a 71-123 chassis with replaced caps and  transferred non working shadow meter in the pristine cabinet right now.
Bob..
The shadow meter was attached to the terminals on the strip bolted to the top of choke #8 (described as A and B ) in the instructions for installing a shadow tuning meter in model 71. I am going to try soldering a 1000 ohm resistor to those terminals. The instructions I just mentioned stated that some of the later 71 models had a short piece of wire connecting A and B which only required removal and replacement with the new shadow meter wires. How could the shadow meter coil replace a short piece of wire?
Hi Bob,
You can solder a 1k resistor across the open coil or I would suspect you could just solder a jumper across it also. Depending on what style sm you have, some are not too difficult to rewind and make functional again.
Philco 39-116 radio and remote
The transformer I located is from a Philco TV chassis, circa 1948. The part number is 32-8391 I do have the replace...Brad Winder — 08:59 PM
Philco 41-221 Restored
Hello Rod, Wow that radio looks great nice job ! Sincerely Richardradiorich — 07:39 PM
Philco 269 - 444 FIVE VALVE VERSION?
From what I can remember the model 444 "People's Radio" used a special tube/valve called a PenDD61, it was the...Arran — 06:54 PM
Nice Radioslford310 — 06:24 PM
Hi Chaz,  You may want to post the tubes used in your radio.   From Radio Museum, it seems that the set uses some ...MrFixr55 — 05:14 PM
Today my grandson and I finished the restoration of this Philco 41-221. It has had all the rubber coated wiring replaced...RodB — 03:19 PM
Hi Brad, I had no idea that the overheating was problematic in this radio.  Do you know the part number of the transfor...RichG — 03:01 PM
From the photo it looks the sockets are screwed and the front one does not even match the hole.morzh — 02:54 PM
Hi Chas a welcome, Perhaps we'll have to reverse engineer this to sort it. So let's start w/what tubes does it use? And...Radioroslyn — 12:28 PM
Hi Rich, From my experience, unfortunately it is not uncommon to find the power transformer in the 39-116 to be overhea...Brad Winder — 09:25 AM
