(12-29-2017, 05:55 PM)PhilcoDom Wrote: With regards to these capacitors, what do they control?
#21: electrolytic condenser
#81: dual condenser
#21 filter power for the detector.
#81 is the MAINS filter, reduces interference coming from power. Have to be Y-rated caps. Both need to be changed but especially the latter.
Threads: 1
City: Greenville, DE
Thank you, Morzh.
#21 filter power for what detector?
Thoughts on why the turntable will not spin despite motor working? Gear driven
(This post was last modified: 12-29-2017, 07:33 PM by
PhilcoDom.)
For the 1st one.
Threads: 1
(12-29-2017, 07:41 PM)morzh Wrote: For the 1st one.
Thanks again, morzh. I will be replacing #21 and #81 tomorrow.
Anyone know or care to venture a guess as to why the gear driven turntable will not spin? I can hear the motor start when I turn the phonograph on.
Is the motor itself spinning?
Threads: 1
(12-30-2017, 08:23 PM)morzh Wrote: Is the motor itself spinning?
Appears to be. If I push up on it just slightly it will make contact with and “grind” against something. When I move the turntable clockwise, the needle arm moves. Counter clockwise it sounds like the turntable is trying to engage.
Threads: 336
City: lawrenceville nj
hi dom
their are 2 different types of turn tables
1 is rim driven = lift up on platter and wheel runs along outer rim of platter
2 is more complex = platter just sits on top of spindle under base is a gear
its two pieces of pot metal brackets with center rubber disc
sam
Threads: 0
City: Milwaukee, WI
Where to find replacements for the #2 problem? I've been scouring the web for something to replace that pot metal disc assembly...
