11-22-2017, 04:04 PM
Houston, we have a problem! There is no pin#6 on the 35Z. See Tube diagram Pin#5 is the plate. What do I do? And I said I knew everything!
48-200 code121 Filament Wiring incorrect
11-22-2017, 05:00 PM
Correct amoundo!
Let's take a journey back in time abt 4hrs ago. >>This is fine if there is something else connect to pin 6 also as it has no internal connect to the tube. A common configuration would be to have the 220 ohm resistor between pins 8 and 6. 6 being used as a tie point also it would have the 1200 ohm resistor connected there.<< So are you saying that there is no terminal on the tube socket for pin 6??? I realize that there isn't a pin on the tube base. When my pals were reading comic books I was down in the basement in my dad's workshop. Perusing his Sam's Photofoacts Vol 1-50 admiring the old set and trying to figure out what all those squiggly meant. Circa 1966 Now I think I've got! Terry
« Next Oldest | Next Newest »
Users browsing this thread: 1 Guest(s) |
