  • 1 Vote(s) - 1 Average
60B Version 2 Grille Cloth
Oh, no!  Not grille cloth again!  I’ve searched the forums but haven’t found a specific reference to version 2.
I finished the cabinet restoration a few days ago, but had second thoughts about the grille cloth.  When I acquired the set it had faded, worn & torn cloth which I assumed was original.  So I replaced it with closely-matching  Radio Daze GRC-03.  Since then I’ve noticed that none of the photos I’ve seen of a 60B Version 2 have this pattern--not even in a 1934 Philco ad picture.
[Image: https://farm5.staticflickr.com/4640/3820...b9687d.jpg]
[Image: https://farm5.staticflickr.com/4589/2505...39f6ba.jpg]
The set has had some previous work done, but it’s pretty old.  One filter cap is replaced with a cardboard electrolytic from the Illinois Condenser Co, so how old might that be?
Do I have the wrong grille cloth?  If so, is an appropriate replacement available?
Thanks from a woefully disappointed…
Henry
Definitely the wrong cloth. Philco had not started using the chevron cloth yet when the 60B Version 2 was being produced.
This version of the 60 also used what is commonly known among collectors as the "70/90 cloth pattern".
An exact duplicate is no longer available, but you can get pretty close with Kenny Richmond's Whiskey Rayon, or Radio Daze's GRC02.
P.S. I hate to tell you this, but in that "after" photo, the cabinet was not toned properly.
Thanks, Ron. I KNEW you would notice the tone. I couldn't tell the difference on the set before restoration--it all looked equally dark. I picked up the error after it was finished. But I had a good time doing it, anyway.
Philco 39-116 radio and remote
The transformer I located is from a Philco TV chassis, circa 1948. The part number is 32-8391 I do have the replace...Brad Winder — 08:59 PM
Philco 41-221 Restored
Hello Rod, Wow that radio looks great nice job ! Sincerely Richardradiorich — 07:39 PM
Philco 269 - 444 FIVE VALVE VERSION?
From what I can remember the model 444 "People's Radio" used a special tube/valve called a PenDD61, it was the...Arran — 06:54 PM
Nice Radioslford310 — 06:24 PM
Hi Chaz,  You may want to post the tubes used in your radio.   From Radio Museum, it seems that the set uses some ...MrFixr55 — 05:14 PM
Today my grandson and I finished the restoration of this Philco 41-221. It has had all the rubber coated wiring replaced...RodB — 03:19 PM
Hi Brad, I had no idea that the overheating was problematic in this radio.  Do you know the part number of the transfor...RichG — 03:01 PM
From the photo it looks the sockets are screwed and the front one does not even match the hole.morzh — 02:54 PM
Hi Chas a welcome, Perhaps we'll have to reverse engineer this to sort it. So let's start w/what tubes does it use? And...Radioroslyn — 12:28 PM
Hi Rich, From my experience, unfortunately it is not uncommon to find the power transformer in the 39-116 to be overhea...Brad Winder — 09:25 AM
