1936 Philco 620B Silent
I turned on my 1st complete restoration, my 1936 Philco 620B Tombstone, to listen to the local news late this afternoon, and got no audio.  Icon_e_sad  Not even static at full volume.  Icon_e_sad
I recall the last time I turned it on, it worked for a minute, then went silent.  Icon_shh
Up to the last time I turned it on, it was my go-to radio to listen to. It's been an excellent performer, so I'm a bit surprised.  Icon_confused
So I'm pulling it down and 1st thing will be to pull and check the tubes.  Icon_wink
[Image: https://farm5.staticflickr.com/4694/2612...47dc_z.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
1st thing I checked was the output tube, the 42. It checked out OK. Next was the 78 (IF), also OK. 75 tested strong on all 3 tests. The 6A7 shows just a nudge under 300 on the OSC section, but my chart says OK if above 100. The Other 78 (RF) tested in the Red, low. Icon_thumbdown
I pulled a 78 from my 620F, and popped it in, and the radio came right on and worked as it always had. Icon_thumbup
Then, just to confirm it was that tube, I popped the original back in, and it worked! Icon_confused Odd. I jiggled the tubes around, checked the grid cap connections, and it continued playing. Maybe it was just a loose connection somewhere. Icon_crazy
For now it's working, so I'll stick it back up on the shelf. Icon_rolleyes
I'll re-visit this thread if it acts up again. Icon_wave
Blessings,
Jeff W.
Jonesboro, Arkansas
Even if tube tests LOW, unless it tests DEAD it usually works, just not so well. With few exceptions, an oscillator might be one.
