Threads: 12
City: Suffolk, VA
Has anyone fixed a Model 680 shadowgraph. I tried the usual hints from the " repair bench" with no results. the vane is free and coil shows 500 ohms resistance. #85 tube is good with 70 volts plate voltage. Thanks in advance Norman
Threads: 212
City: Seattle
State, Province, Country: WA
Any chance that the bar magnet has become demagnetized?
500 ohms sounds low to me for the coil resistance - typically they're >1K.
Even if 500 ohm, still should react.
I second the magnet thought.
Just for grins take a 9v battery - to the chassis and + to the grid cap of the 85. Should cause the vane to deflect.
Threads: 12
City: Suffolk, VA
Thank you folks for the hints. Norman
