Threads: 1
City: Maple Grove, MN
I'm brand new to the Philco and vintage radio world. I recently acquired this 1966 Philco console and am in need of guidance.
I know it's a 1966 because I saw an identical one for sale on ebay.
I know it's a trans because there are no tubes.
That's all I know. THhere are two wires hanging down in the back that I don't know where they go. I'd like to plug them in to the proper place. Everything seems to work correctly, except the phono is a little slow. I assume it needs a new belt.
I can supply higher res pics if needed
thanks,
Jack
Threads: 267
City: Bandon
Welcome to the Phorum!
Can't tell you what that wire goes to, I've not worked on anything that new but someone here will likely be able to help. It looks a bit like the old 300 ohm twin lead TV antenna wire to me.
Hi Jack and welcome,
+1 Bob
Looks like twin lead to me too. With that being said it probably connected a pair of screw terminals on the missing back cover. Would be for connecting an antenna for the FM band.
GL
I think that it may be a bit newer then 1966, it's probably closer to 1970. My parents used to have a similar unit that was re-branded as a Sears Silvertone and the layout was very similar to that, it had a Spanish style cabinet though, and was around 1972 vintage. I think that someone posted an almost identical one to the one my parents had in another thread, except it had the Philco name on it, here it is:
http://philcoradio.com/phorum/showthread.php?tid=10988
Here is another that ended up in France somehow, maybe imported by a private party, unlike the unit my parents had it has oval speakers, the chassis looks a bit different then yours:
http://philcoradio.com/phorum/showthread.php?tid=17664
(This post was last modified: 05-15-2018, 02:46 AM by
Arran.)
Threads: 1
The wires have female spade connectors, so I don't think they're for an antenna. There is a box on the back for "Tape out" with some RCA connectors. It seems to be a tight fit, but I'll give it a looksie!
https://www.ebay.com/itm/1966-Philco-ste...SwyTZUX6oS
This is the identical one for sale. The price seems a BIT steep!
Yes, the fleabay one is high by about 20 fold, minimum, those things are hard to give away where I am, let alone sell for any amount of money, you would think that they could get a new needle for it at least? I think that you may be closer on the date then I was, now that I can see the control panel, the last time I saw one with similar chrome finished knobs it was sitting with a free sign on it next to the road, but it was shorter in length, and the cabinet was more of a "modern" style.
(This post was last modified: 05-16-2018, 04:23 AM by
Arran.)
Threads: 1
Mine was free so i don't mind having a project!
Threads: 3
City: Chesapeake VA
Pictures of stampings on speakers and other components will give a idea when parts were manufactured...
Without concrete evidence, I rarely believe anything stated on ebay pertaining to vintage electronics...
Tom
(This post was last modified: 05-17-2018, 05:06 PM by
35Z5.)
Threads: 1
Agreed.
Upon further investigation, I believe the mystery wires are for an external FM antenna!
Now I'm on to the belt issue....
