MEMBERSHIP BENEFITS
Membership on the Philco Phorum is free and requires only that you complete the registration page followed by a brief review by one of our moderators.  We do this to help keep spammers off the pages.
The benefits of membership include the following:
• Ability to post messages and reply to messages so you can ask and answer questions.
• Images will be visible in the posts
• Ability to send a private message or email to other members
• Access to Members Only discussion and information topics including:
    Restoration Notebook
    Downloadable files with many useful documents for Philcos
    A Bar & Grill section for discussion of non-radio topics
    On-line sales discussion section
    Swap Meets
    Members Items For Sale
    Wanted Ads
Join us now by going to the Registration Page
Remember to include your CITY & STATE in the Location Profile section, it is REQUIRED.
IF you live in Canada include your CITY and PROVINCE.
If you live outside the USA and Canada then only your Country is required.
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM
Jackson 715 not working
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red. Red is Bad. Green is Clean.morzh — 01:30 PM
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM
(Insert Homer Simpson "DOPF" Here.) When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil. It wo...morzh — 08:44 AM
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM
As Rod said, it is OK to use a fitting speaker, and then look for an original one. If you buy a Hammond 125 output tr...morzh — 08:15 AM
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 3131 online users. [Complete List]
» 2 Member(s) | 3129 Guest(s)
