37-93 hot resister
so a hi voltage winding shorted to xfrm housing?
you may be able to take it apart and fix it,output leads may be crumbling like the rest of the wiring.
phil
Icon_biggrin OK, I rewired the transformer and now the resister does not get hot. The old wire was brittle and it had crack in just the right place for voltage to jump to the chassis. I was suspicious of that 134 VAC on the center tap. Now there is just .5 to 2 VAC there.
Later I will see about aligning the radio and see if I can pick up anything.
Thanks for you help Phil and everyone else.
sorry i jumped out,had to take an a.s.e. L1 test-BRUTAL!!! but i passed!
good the you cleared the short,radio is working now?
aaahhh the sweet sounds of success!
good work and welcome to the addiction,now go find another one.
phil
Phil
Like I said, thanks for the help. It's receiving, just needs a few tweeks. Got a Model 60 on the back burner.
the 60 will be fun,be sure to read ron's 60 info,many many changes made in that one.
phil
