Threads: 1
City: Philadelphia
State, Province, Country: PA
Hey Everyone,
I recently purchased a Q1791WA (or at least that's what I believe the model number is).
Aesthetically the piece is in great condition with signs of wear and slight dings from moving around.
On the audio front, there is a terrible hum when the radio is turned on, and I'm unable to get the turntable or reel to reel players to work.
I'm finding very limited information about this piece online and wanted to come here for a bit of guidance on how to kick off my first project!
Any help is very much appreciated!
(This post was last modified: 08-19-2019, 09:44 PM by
Qbinalex.
Edit Reason: typos
Threads: 532
Welcome!
Treat it as any antique piece. Even if it is much younger piece than those from 1930-s, it still has to be recapped when it comes to electrolytics and paper caps. The resistors might fare better.
And then there are mechanicals.....for tape recorder you could possibly get some insights from Tapeheads.
Threads: 1
City: Philadelphia
Thanks Morzh! That was my plan! And thank you for the advice on Tapeheads, I'll look there for a bit of help.
Here are some photos of the piece as well!
Threads: 14
City: Bakersfield, CA
Wow. that's a lot of radio!
Threads: 5
City: Woodland, CA.
Nice box..... Now show us them pretty insides..
Threads: 7
City: Austin
State, Province, Country: Minnesota
And I thought I was ambitious restoring my first radio
Threads: 7
City: Austin
I suggest you replace any wiring that looks bad too as long as you’re in there. I’m having to do that because a few wires just crumble when touched
Threads: 1
City: Philadelphia
Threads: 114
City: Sneedville, TN
I suggest you look here. The service information is not free, but it is not expensive either. I have used it myself:
https://www.samswebsite.com/
Threads: 25
City: Louisville, KY
Hmmmm, . . . nice VM changer!
They gravitated to BSR later on with a dip in quality.
(This post was last modified: 08-20-2019, 06:47 AM by
Jake Blake.)
Agree with Mike the Druid. If you don't find it in Sams Photofacts...you probably aren't going to find it. And I would be frankly surprised if it isn't in a Photofact folder.
Threads: 1
City: Philadelphia
I was able to find all the documentation on Sams Photofacts. Thanks all for the suggestion/help.
Threads: 1
City: Philadelphia
Hello all,
The quarantine / self isolation has kicked my "restoration" into high gear.
I've restored the VM changer and have it moving and playing tunes.
Now on to fixing the hum emitting from the speaker... After checking all speaker wires and ground I'm pretty sure this is capacitor issue.
Is there a preferred/recommended site that everyone uses for purchasing capacitors?
I'm specifically looking for two Philco 30-2593-14 (4 uF / 25NP).
THANKS!
Would that cap be connected between two of the speakers?? Is the hum present when you select the radio or tape position?
Threads: 1
City: Philadelphia
Hi Radioroslyn,
The cap is connected to the 12'' speaker which is connected to the remaining speakers.
The hum is present when I select radio am/fm, tape, and/or phono.
Thanks!
(This post was last modified: 04-20-2020, 08:45 PM by
Qbinalex.)
