How to remove power switch 41-608
Merry Christmas to all!  New problem. One of the two wires in the power switch came out. How do I remove the switch to reconnect the wire?
https://philcoradio.com/phorum/showthread.php?tid=89
or https://philcoradio.com/phorum/showthread.php?tid=14923
I'm pretty sure your set has the radio off/on switch built in to the pushbutton assembly. It's not uncommon on these switches to have burnt contacts or if they have been arcing for a while just the fall apart.
 Should see your choke on Monday.
I put a new switch in today. I used the one from lowes but didn't disassemble the new one. Instead I filed some of the tip off of the stem (about 3/16 of an inch), used epoxy to glue the feral to the old switch location and screwed the switch in until it functioned correctly. Locked in place with the lock nut that came with the switch and now it works perfectly.
Does your specimen of 41-608 have the extra recording tone arm? Icon_wtf
No someone removed the bol and replaced it with a standard phonograph.
