37-620 voltages
Got 6P cheap at a flea market with bakelite carrying case. Don't like case took it off. The P has protection so if you happen to have it in the ohm setting and you measure voltage it simply pops the breaker on the front panel. No smoking resistors or burnt switch contacts to replace.
I don't use mine a lot either but it does come in handy from time to time. Gotten lazy using the digital meters.
