  • 1 Vote(s) - 5 Average
Philco model 45 dial pulley slipping
Hello all, I have a model 45 with a slipping dial drive pulley . This is the pulley on the same shaft that the knob is attached to. Has anybody had this problem and how did you fix it? Thanks in advance for any ideas. Norman
https://www.philcorepairbench.com/dial-s...-28-29-45/
nice poem but how does this tell me about my problem?
Did you click on CLOSE on the schematics not available during covid 19...
Missed it, but I didn't:
Dial Slip in Models 28, 29, 45
In the Models 45, 29 and 28 there is a small coil spring at the rear end of the drive shaft. Dial-drive slipping in these models can be corrected by tightening the two hex nuts at the end of this spring. These nuts regulate the spring tension, which in turn affords proper operation of the reduction-drive assembly. In some remote cases it may be necessary to replace this spring when it has been compressed beyond its limit of elasticity. This spring is known as Part No. 28-8256 and lists at 70 cents per hundred [1935 prices, of course].
From the Philco Serviceman – March, 1935.
Pliny the younger
Thank you Chas. Will look into this. Norman
