Threads: 140
City: Lansdale
State, Province, Country: PA
Just started to work on a 46-1203.. found that the resistor R2 ( 50,120 ohm) was missing.. Question what power rating do I need for a replacement ? this is the resistor the is in the filament string..
This radio uses a 50X5.. Not the 50Y6GT
Skip
Threads: 21
City: Wellborn Florida
Posting a link with info looks to be 2 watt.
http://www.nostalgiaair.org/Resources/585/M0013585.htm If it was mine due to higher line voltages would go with 3 or 5 watt if they would fit.
Threads: 140
City: Lansdale
Is there a way to check to see if the electronics are bad or the cartridge is bad.. i get no sound when either touching cartridge or scraping the needle..
Skip
Did you get the radio side of things working??
Threads: 140
City: Lansdale
As Norm said you need a cartridge. Drop Kirk a note and he can help you pick a suitable replacement.
Threads: 140
City: Lansdale
