Philco 46-1203
Just started to work on a 46-1203.. found that the resistor R2 ( 50,120 ohm) was missing.. Question what power rating do I need for a replacement ? this is the resistor the is in the filament string..
This radio uses a 50X5.. Not the 50Y6GT
Thanks
Skip
Posting a link with info looks to be 2 watt.    http://www.nostalgiaair.org/Resources/585/M0013585.htm      If it was mine due to higher line voltages would go with 3 or 5 watt if they would fit.
Is there a way to check to see if the electronics are bad or the cartridge is bad.. i get no sound when either touching cartridge or scraping the needle..
Skip
Did you get the radio side of things working??
YUP Working great..
Skip
As Norm said you need a cartridge. Drop Kirk a note and he can help you pick a suitable replacement.
Thanks
Will do
Skip
