46-350 - High Voltage on 117Z3 Rectifier
Hello,
I'm restoring my first tube radio and am hoping to get some advice. I have a 46-350 which I picked up at a thrift store. I threw it on the variac and I'm seeing very high DC voltage on the cathode of the 117Z3 rectifier. From what I've read on this forum and on the schematic I should be seeing ~90V DC from pin 6 (cathode pin) to B-. When I check the voltage I'm seeing about 163V DC between pin 6 and B-. Also, I noticed I get the same voltage results if I test from the B- terminal or the metal chassis as the ground. From my understanding, the B- should be an isolated ground.
As a test, I disconnected the wire from pin 6 to R100A, just to isolate the circuit. When I do this I'm getting about 70V DC from pin 6 on the 117Z3. If I reconnect the wire the voltage jumps back up to 163V DC. I have two rectifier tubes and I've tried both tubes, they both showed similar results. Just as a side note both tubes tested good on my tube tester.
The only other change I've made is replacing the filter caps. I did double-check polarity and size/voltage and everything looks good.
Does anyone have any ideas on why the voltage would be so high at pin 6?
Some things need to be rectified first.
- Do you apply 120VAC from the variac or 110V?
- Do you have the speaker plugged in and all the tubes hot and conducting like they should? Is the output tube 3Q5 conducting with the voltage on the plate?
Hi Morzh,
Thanks for your response.
-I'm applying 110V from my variac.
-I didn't have the speaker plugged in when I was testing but I tried it and nothing seemed to change. None of the tubes besides the rectifier tube is heating. I testing the 3Q5 plate voltage (Pin 3) and it's showing the same voltage as the rectifier, 163V DC.
No tubes heating means no conduction means no load means high voltage.  Here's a youtube video on your radio that might help. I didn't watch it. https://www.youtube.com/watch?v=G5B5Odql5tw
Check R-100 a,b, and c for proper resistances. If those are bad the filaments won't light.
Thank you for the suggestion. I did some more testing and found I don't have filament voltage. It looks like part of the candohm resistor has gone bad. I'm not getting any voltage on the last post after the R100C resistor and nothing on the filament pin on 3Q5. I just placed an order for a 900 Ohm 5W replacement. I'll keep everyone posted once I solder in the replacement resistor. Fingers crossed I can at least get the tubes warming.
It's important that the 8.5v at the end of R-100C ends up being 8.5v after you get done replacing that resistor. Too high and it shortens the tube's life. Too lo and the mixer/osc won't work so no reception. The rest of the voltages are not particularly critical within reason.
Hey guys, remember these are 1.4 volt tubes. They won't create a lot of heat or produce a warm glow (maybe the 3Q5). I install a 9 volt zener diode across the filament voltage as a safety net.
Basically you have no load hence high voltage.
When you run 110V AC through a half wave rectifier then there should be no more than 120V DC no load output. Sounds like something is connected wrong in the power supply filter.
Rod
Not really.
Unloaded rectifier with a capacitor becomes a peak detector. This will charge the cap to the peak value of 155.54V in case of 110VAC.
That's right, I must have been thinking loaded voltage. So how does he get the 163?
115VAC is exactly 163V peak.
The Variac has tolerances.
I am sure if measured by a DMM, instead of looking at the Variac Voltmeter, it will show 115V.
An ac voltage is dynamic it's constantly changing.  Because it's constantly changing it's voltage is not a single value. The peak value is the highest value seen. If I remember correctly to find peak value you multiply by the square root of two.
The voltage reading from a typical outlet is said to be approximately 117vac.  The ac value assigned is from the power that's equivalent to 117VDC when either are measured into same resistor or resistive load.
sine wave AC peak is 1.414 times the RMS value, thus for a stated line voltage of 120VAC the peak voltage is 169.7 V
