Threads: 5
City: Beverly Hills
State, Province, Country: Michigan
Working on this radio, and its has a 25MFD@25Volts Electrolytic in the schematic, and I have a 22MFD@25Volts non polarity cap, plus a 25MFD@50Volts polarity cap, question is can I user a non polarity cap in this situation or just go with a polarity electrolytic. Plus the 25MFD@50Voltsis about 25% of the size.
All help is appreciated,
Rick
Threads: 8
City: S. Dartmouth
State, Province, Country: MA
I would use the 50 volt cap FWIK it costs less and will work. Non-polorized caps are a bit more costly value for value... chas
Pliny the younger
Threads: 532
As Chas said. The type of the cap in this particular application does not matter much, so pick the one that is easier to solder/cheaper...easier to work with.
Threads: 5
City: Beverly Hills
I am putting the finishing touches to this radio. AM plays fine, FM nothing at all.
What am I not seeing, or in this case not hearing.
Thanks to all that has helped me on this project. It been a labor of love.
Rick
Threads: 21
City: Wellborn Florida
Had the same problem with mine AM good no FM changed the 12AT7 FM was working then changed the 19V8 big difference in FM. Find that having extra 12AT7 tubes is a good idea if you are playing FM on tube radios.
Threads: 5
City: Beverly Hills
