RF demodulator/detector probe
Hi All, anybody have a recommendation for a RF demodulator/detector probe to use mainly with a signal tracer or sometimes an o scope? Would like it to have a BNC connector on the end for attaching it to my equipment. A quick search seems to find X1-X10 probes, not detector probes. TIA
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Ron,
You up to making your own? I can post the [simple] schematic for the one that came with an Olsen KB-141 Signal Generator and Tracer.
Thanks fenbach but that’s exactly what I did. I bought some cables with a BNC connector on one end and redid an old probe replacing a capacitor and the diode with a 1N34!
Ron
Jackson 715 not working
Now that you posted the schematic, I don't know why that Sprague electrolytic cap is across the meter, as it is not indi...MrFixr55 — 05:51 PM
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red. Red is Bad. Green is Clean.morzh — 01:30 PM
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM
(Insert Homer Simpson "DOPF" Here.) When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil. It wo...morzh — 08:44 AM
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM
As Rod said, it is OK to use a fitting speaker, and then look for an original one. If you buy a Hammond 125 output tr...morzh — 08:15 AM
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
