precise 713A power lab
anyone have a decent schematic for a precise 713A power lab? the only one i could find was at
https://antiqueradios.com/forums//viewto...p?t=309831
it is useable, but barely.
Was there any info found for this tester
Some one must have a good copy of this.
Moe
looks like radiomuseum has a schematic for download although it may only be the actual schematic not the other pages. It might be more readable. You have to fill in a bit of info to get the download but I've done it before, not hard.
Thanks, I have those already.
Thought there might be something better out there.
A little less fussy
Moe,
I see you discovered the "information" posted at https://antiqueradios.com/forums//viewto...p?t=309831. Non too clear in my estimation.
It has a variac [as you must know]. But with output voltages from 90AC to 140. Any idea why it wasn't designed to start at 0 volts?? Or if it can be modified to start at 0 volts.
Bob
Sorry, Have not spent much time on this unit. Just too limited of info to continue.
Thanks for the interest.
Moe
Jackson 715 not working
Mrfixr55, its working now. I cleaned the switches and sockets with spray cleaner. Thanks for helping on this one.daveone23 — 06:26 PM
Now that you posted the schematic, I don't know why that Sprague electrolytic cap is across the meter, as it is not indi...MrFixr55 — 05:51 PM
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red. Red is Bad. Green is Clean.morzh — 01:30 PM
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM
(Insert Homer Simpson "DOPF" Here.) When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil. It wo...morzh — 08:44 AM
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM
As Rod said, it is OK to use a fitting speaker, and then look for an original one. If you buy a Hammond 125 output tr...morzh — 08:15 AM
There are currently 4158 online users. [Complete List]
» 1 Member(s) | 4157 Guest(s)
