RCA 6XF9 AM/FM
I have a problem with one of these. I need to get it out of the case to repair it.
However,.... the darn thing resists all efforts to remove the knobs. Does anyone have any idea how these things come apart ?
The knobs will pull out only so far and then stop,.. like they are hitting a spring or catch.
What's the secret ?
First make sure there are no set screws anywhere on the knobs. If there are, of course you will have to ease them back.
If that's not the case, if you can somehow get in there and spary a little WD40, wait a few hours, or overnight, and then try gently to coax them out with a couple of putty knives 180 degrees apart, you might get them off. Provide a barriar between the cabinet and the knobs, like a piece of thick cardboard, so you do not mar the cabinet.
Sometimes the "spring"steel insert that is provided to create a tension between the knob and shaft gets corroded and rusts, and it forms a pretty tight bond with the knob spring.
Be very patient, and let us know what you find.
Thanks,good idea,... it was actually going to be my next "try". I recall hearing at another forum that these were a particullarly hard one to get apart,... I just can't remember where I saw the answer. And yes, I'm older than the radio. : )
If anyone else knows something, it would be appreciated.
John
Use a little pb blaster it really get in the rust . take a piece of insulated wire loop around knob and pull useing your thumbs against cabinet.
This should work. no scratch getter offer method. Icon_biggrin But do look good for set screws and catches. Icon_wink
Philco 46-480 Cabinet Restoration
I have since gotten the cabinet stained and toned. I saw a video online of another guy renovating a 46-480, and he used ...jrblasde — 07:37 PM
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
There are currently 1762 online users. [Complete List]
» 2 Member(s) | 1760 Guest(s)
