Philco 46-1226 Code 125
A customer brought me a model 46-1226 and I discovered it was a Code 125. The schematic was never drawn and the closest you can get is a Code 122. There are also several factory revision sheets which address factory changes to the 122. Hoping that someone on the forum can help. The owner pulled all of the tubes and put them in a bag. I cannot even start. The power supply is different since it uses a PM speaker. Please contact me if you can help.
Thank you,
The documentation in our library includes the code 125 power supply info you mentioned along with the changes that go with it. Does this help?
https://philcoradio.com/library/download...6-1947.pdf
Yes, this helps.
Thank you
Icon_thumbup
